  3. Valor ODB++ Inside Export issue
  • Views 15762
newpic
newpic over 15 years ago
When export board to ODB++, it ask to download the Valor ODB++ software.
I download Valor ODB++ Inside packing (Allegro links)
After download complete, run the  install, There is error "Can not get the 'path' data."
Every time I use export/ODB++ , it always ask to download again like above.
Anybody use Valor ODB++ and I need some instruction to fix my error
 Thanks in advance
  • steve
    steve over 15 years ago
    Make sure you have admin rights when you install Valor. It needs to add an environment variable ALLEGRO_BRD2ODB = C:\valor\ODB++Inside and a path of %ALLEGRO_BRD2ODB%/nv/bin and if you don't have admin rights it will not be able to add these variables.
  • newpic
    I have re-install it with admin rights, the same error still popup, it still keep in the same popup error that the ALLEGRO_BD2ODB system not defined.
    I even added the following variable to the set and path.
    It is not working.
    Is there any other to go around it?
    Please help.
    Chai Xiong
  • eDave
    eDave over 15 years ago
    Your ODB++ Inside paths don't look correct to me. The path should contain: C:\Valor\ODB++Inside;C:\Valor\ODB++Inside\nv\bin Move the %ALLEGRO_BRD2ODB% paths to the end of your path. Valor's find command is possibly conficting with the Windows find command which may be being used elsewhere. Regards, Dave
