  3. Drill Table problem
  • Views 16124
Drill Table problem
archive over 16 years ago
Hi all
I am using V16.2 Allegro.
When generating the drill table I get text lines jumbled together and some lines of the table too close and crossing into the text. I used to know how to fix this but it has been some time since I have had to.  Any ideas as to how to fix this problem?
Alan
APF Circuit Design Inc.
Ottawa Canada
  • steve
    steve over 16 years ago
    Since 16.0 Allegro now generates seperate drill tables for each drill pair (top-bot , 1-2, 7-8) etc. You probably have more than one drill table on top of each other. Use edit - move then change find filter to groups, then select the table, it will become attached to the  mouse, re-position until you have moved all the tables apart.
  • shangwu
    shangwu over 16 years ago
     Manufacture --> NC --> Drill Legend
    In Legends box, select "By layer" instead of "Layer pair".
