  3. Outputting an IPC Netlist
  • Views 16255
CubbyBear
CubbyBear over 15 years ago
How do I export a netlist in IPC format using Allegro 16.2?
  • Rik Lee
    Rik Lee over 15 years ago
    Use the menu picks
    File >Export >IPC_356; set the IPC Version (IPC-D-356 or IPC-D-356A) and other options such as output name and then select 'Export"
    Additionally, you could use the batch program ipc356_out from a terminal/shell window. For help on that type in the terminal/shell window
    ipc356_out -help
    ~Rik
