  3. How to get a pour to update the connections?
  • Subscribers 163
  • Views 14135
kanonfodder
kanonfodder over 16 years ago
Some of my pours are automatically connecting themselves to the surfacemount pads.  However my ground and power planes are not connecting to the thru hole pins, and I did a pour for power on coupling caps, and then put in vias to connect the pour to the power plane, but it isn't updating.
 Thanks.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Are you using OrCAD/Allegro PCB Editor or OrCAD Layout?
    If you're using PCB Editor I would recommend that you check that the planes are set to positive under Setup->Cross-section?
    Also check under Shape->Global Dynamic Parameters that you've selected the correct Artwork format inside the "Void controls" tab and set Dynamic fill to smooth inside the Shape Fill tab.
    Best regards
    Ole
  • kanonfodder
     Thanks, it was the negative artwork on xsection.  The other was they snuck in 3.3Vdc and +3.3Vdc on me.
