  3. part L293D
  • Views 12722
part L293D
banzaicorp
banzaicorp over 15 years ago
 im draw a scematic diagram for line follower robot using part L293D as its motor driver. but the problem is in the scematic diagram,not all pin for that ic is visible.the pin that not visible are VCC1,VCC2,GND1,GND2,GND3 and GND4.pleas help me!!!
  • Jerry GenPart
    Jerry GenPart over 15 years ago
    Look into the part’s chips.prt file. In this file, scroll down to the bottom, you may
    find a line in the ‘body’ section  listed something similar as –
    POWER_PINS='(GND1:10; GND2:11; GND3:12; GND4:13;VCC1:20;VCC2:21)';
    This is where the power and ground pins for a part can be listed if the
    librarian does not wish to physically show them on the symbol.
    They will be connected to the net names specified in the POWER_PINS
    line.
    Jerry
  • stump1019
    stump1019 over 15 years ago
    Don't forget the use of the POWER_GROUP property in the event he wants to change any of the voltages.
