  3. Capture - rev
  • Views 837
Capture - rev
shangwu
shangwu over 15 years ago
In Capture schematic there's <RevCode> on the lower right corner.  I can manually change it, but how do I change the number across all the sheets at the same time?
Thanks.
  • redwire
    redwire over 15 years ago
     From the project view select the design and Edit->Browse->Title Blocks and copy and paste the rev in the "spreadsheet"
    Or right click on the project and Edit Object Properties and then select the Title Blocks tab and change it in that spreadsheet.
  • shangwu
    I tried the 2nd method and it worked.
    Thanks.
