  3. Problem starting Cadence Programs
  • Subscribers 162
  • Views 14521
Verdura
Verdura over 16 years ago
 I'm a sysadmin and I have a problem with Cadence programs running in a pc. The thing is that the following tools don't work: Allegro, Capture from Orcad 16.2. But the tool Layout and Pspice work fine! That only happens in a single pc (but is the only one with server 2003), the rest of the pcs (with Vista) work fine. Is there any compatibility with Windows server 2003?
I've noticed that it gets stuck in the mspinfo.exe and cdsNameServer.exe (probably!!!!). Is there any well know bug? Any update?
Thanks a lot for your help...
  • oscar migs
    oscar migs over 16 years ago
    2003 server works, but it also depends on your hardware.  What kind of processor are you using?
    Best Regards,
    -oscar
