  3. Better way of turning off all classes and subclasses from...
  • Replies 9
  • Subscribers 166
  • Views 17883
Better way of turning off all classes and subclasses from view?
kanonfodder
kanonfodder over 15 years ago
I have PCB Editor 16.2, and there has got to be a quicker way of turning off all the classes and subclasses so I can then turn on only the ones I want for when I'm making the artwork classes.  Only way I've seen is to manually go through every class and turning them off one by one.
Mike
  • Amardeep
    Amardeep over 15 years ago
    On the color dialog box select Global Visibility 'Off"
  • mcatramb91
    mcatramb91 over 15 years ago
    You can turn everything invisible quickly by typing the following on the Allegro command line:
    skill axlVisibleDesign(nil)
    If you have access to SKILL this command should work.
    Hope this helps,
    Mike Catrambone
  • steve
    steve over 15 years ago
    For your artworks you could use a parameters file which will set these up for you automatically. Go to an existing board that has the artworks already defined and use File - Export - Parameters, check the boxes and export. On your new design use File - import and they should be there.
    An alternative is to use color view files. Set the colors as you want then use View - Color View save and store the color file. This name will now appear under the visibility tab views drop down box. A quick way to change the display to what you want. There is also a user preference (viewpath) so you can store all view files in one location and use them on all designs.
  • fxffxf
    fxffxf over 15 years ago
     Alternatively to quickly turn off all layers if you product doesn't have Skill you can type:
         color -globvis off
    Do a "color -help" for more options.
  • ghurley
    ghurley over 15 years ago
     I have a hotkey alias (built from a script) that turns everything off.
    I place the alias in my env file.
    Good to go...
     Greg
