  3. SPECCTRA quit unexpectedly with an exit code of 3
  • Views 17222
fsahebi
fsahebi over 15 years ago
Hello all,
 I am new to PCB design and using examples from
Complete PCB design using OrCAD Capture and PCB editor book and when I try autorouter I am getting
 SPECCTRA quit unexpectedly with an exit code of 3. Please verify that you are running SPECCTRA version V9.0 or later. What am I doing wrong that I am getting this?
Best regards,
Fred
  • oldmouldy
    oldmouldy over 15 years ago
    Most likely you have a space character in the design name, design path or login account name. SPECCTRA is a multi-platform appilcation, UNIX platforms have little tolerance of spaces and SPECCTRA is no different in this respect.
  • fsahebi
    No I don't have a space character anywhere.
    Fred
  • Rosh
    Rosh over 14 years ago
    I also having the same problem if you solve it tell me. I will also try to find a solution Best Regards RJK
  • orcadteam
    orcadteam over 12 years ago
      Am also had a problem which mentioned above.
      Pls anybody help us, how to resolve this.
    Kannan.S
  • BillZ
    BillZ over 12 years ago
    The solution was posted.  Error exit code of 3 is usually a space in the folder name. Example c:/Documents and settings has 2 spaces. Also make sure your .brd does not contain spaces. If those do not have spaces your login name may have a space. This can result in a similar error.
    I would create a test folder ex: C:\test and save my .brd into it and name it test.brd  If you still get the error list your User Preferences and Check this variable: set  username     = billz  Verify it does not have any spaces.
    BillZ
