  3. Parameters - getting from DC analysis to TR analysis
  • Views 1533
JohnWard
JohnWard over 15 years ago
PSPICE: I'm modelling a pressure sensor and have set up some parameters (including "Pressure") which model the device sensitivity and outputs vs pressure, temperature etc using formulae in the parameter definitions. This runs as a DC simulation, and I can sweep the parameters as desired - so far so good.
 However, I need to be able to run TR analysis which means being able to introduce a stimulus (eg. VSIN) to drive the circuit. I can't seem to work out how to 'map' the output of a stimulus (which is a voltage, or a current) to drive a parameter formula. There must be some way of doing this, but it's not obvious what it is. Help appreciated!
 Thanks, John.
  • oldmouldy
    oldmouldy over 15 years ago
    A Stimulus is connected to a "special" part called a VSTIM for voltage and ISTIM for current, place this in a schematic, give the implementation a name and right-click>Edit PSpice Stimulus to get the Stimulus Editor running, then define the stimulus. IF you already have the stimulus defined, make sure that you add this to the design before using the stimulus - Edit the Simulation Profile and use Configuration Files tab to add the stimulus, STL, file to the design.
    If you just need a Sine source, use the VSIN or ISIN parts, they are a bit easier to use for simple sources, just place the part in the schematic and wire it up, the existing source may need to be removed.
  • JohnWard
    Thanks for your reply. I agree this is the way to add a stimulus, but I think I didn't explain my problem well enough.
     I have a set of complex formulae added to 'parameters' which take various variables such as 'pressure' and 'temp' and calculate sensor output characteristics. The values of these calcs can be used to drive various pieces of circuit input by using them in {brackets} as component values etc.
    However, what I need to be able to do is drive something like 'pressure' from a sinewave source eg. VSIN or VSRC (ot VSTIM). The output from any of these sources is a voltage, and the value of this voltage cannot be used as far as I can see in a formula in a parameter. What I'm saying is you can go from a parameter to a voltage (or current), but not the other way.
    I guess I could use a circuit element that is driven from a parameter rather than a voltage (ie. change from using POT to some Epart equivalent circuit), but I'm not sure that the parameter calculations are re-visited at every time step in the sim, I suspect they are done at the beginning after the DC bias point calculation.
