  3. Help with "FIXED" property
  • Views 12141
croc4
croc4 over 15 years ago
Hey guys,
I'm having an issue with some symbols that are "fixed" when I select them and choose "unfix" from the drop down menu, I see a message in the command window that  the fixed property has been removed, but when I then try to move it, it claims the symbol is "fixed" ;-/. So I'm at a loss to correct this puzzle. I'm using Allegro 16.2.
 output from command window
(selecting unfix from the drop down menu of the symbol)
Property FIXED removed from element Symbol: AMP_747250-X at 1358.80, 161.42.
Command >
(Now trying to move that same symbol)
Cannot edit Symbol "J23". Component Instance "J23" has the FIXED property.
No valid items selected for the current operation, exiting.
Croc
  • mjmessinger
    mjmessinger over 15 years ago
    You can try using the Unfix toolbar item (or type "Unfix" on the command line), select Comps in the Find Filter and then select the symbol that you want to unfix.
  • croc4
     I have tried that and I still get the same result, it will not allow me to move it, Here is the output from the command window
    Command > unfix J23
    Command > move J23
  • Bennigin
    Bennigin over 15 years ago
    Make sure your Find filter is correct. Trying selecting Component instead Symbol in the Find Filter or vice versa.
  • tomoo
    tomoo over 15 years ago
    The FIXED property might be attached not only for the symbol(AMP_747250-X) but also for the component(J23). The opposite is true.
    Please check the component property, and if it has FIXED property then you should also unfix the component element. (Or symbol property, or etc)
    FYI.
    A quick other method to solve the problem:
    Unfix command > RMB > Unfix All
    Hope this helps.
    Tomoo
  • croc4
     Ah, That seemed to have corrected the issue.
    Thanks guys,
    Croc4
