  3. design reuse
  • Views 14212
design reuse
stellar
stellar over 16 years ago
 I know this is a memory test for some of the Layout users here but remember grouping parts then using design reuse to arrange identical groups. Does Editor have such ability?
  • steve
    steve over 16 years ago
    If you are using 16.3 Allegro L or greater then you can try using the Replicate function (part of the placement application mode). Select the items you want to group then RMB - Place replicate create, make your group then use the place - replicate - apply to use it. It will work in 16.2 Allegro but only symbols (no etch). That was one of the enhancements at 16.3
  • steve
