  3. rf design(rf option) design with capture as Schematic Tool...
  • Subscribers 163
  • Views 718
rf design(rf option) design with capture as Schematic Tool-163
MAAC
MAAC over 16 years ago
Few queries on RF option
  • Is it possible to deisgn RF boards using RF option if iam using capture as the schematic tool
  • where are the components located which are shown at RF-Add component & options tab....which PSM path
  • why are the pads of these components are of negligible size
  • can i add the rf components on to the pcb directly without adding from schematic
  • Ejlersen
    Ejlersen over 16 years ago
    Hi Maac
    Where in the world are you located? Your local Cadence reseller (Channel Partner) may be able to help you regarding the Capture - RfPCB flow and schematic symbols for Capture
    Best regards
    Ole
