  3. Ratsnest Geometry
  • Subscribers 166
  • Views 13703
Ratsnest Geometry
dschaefer
dschaefer over 15 years ago
How do I control the ratnest shape in Allegro?
Default appears to be some form of angled bus tap, all I want is straight point to point. I know I had this set previously but can't remember what the control was.
  • mcatramb91
    mcatramb91 over 15 years ago
    I think what you are seeing is caused by the Voltage property defined on the nets for SI.  Removing the Voltage properties your will see a point to point Ratnest.
    Hope this helps,
    Mike Catrambone
  • steve
    steve over 15 years ago
    Also have a look at design parameters - dsiplay tab then the ratsnest geometry and ratsnest points to see if that helps.
  • dschaefer
    Steve,
    That was it – thanks!
    Dave Schaefer
