  3. Translate PADS schematic to OrCAD
  • Subscribers 166
  • Views 14403
zeebo
zeebo over 15 years ago
I am using PADS9 for schematic and PCB. My ODM partner in Asia is using OrCAD capture CIS 10.5 for schematic. What's the best way to translate the PADS schematic file to OrCAD capture ? Thanks.
Dan
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    I would recommend that you contact Igor at Elgris Technologies www.elgris.com - they have a PADS2OrCAD translator or can do translation as a service. The translation quality I've seen from them is very high quality.
    If they do it as a service they guarantee that the netlist from Capture has the exact same connectivity as the one from PADS. If you then decide to buy the tools, then you'll get their configuration files used for your translation service (they know all the tricks in the book to get a good translation)
    Hope this helps.
    Best regards
    Ole
  • Ejlersen
    Hi
    Hope this helps.
    Best regards
    Ole
  • FormerMember
    FormerMember over 7 years ago in reply to Ejlersen
    Full EDA translation  from old and new PCB and sch tools including library rebuild
    http://www.cadprodesign.ca/
    info@cadprodesign.ca
