  3. Physical constraint error
  • Subscribers 166
  • Views 13117
Neha Anu
Neha Anu over 15 years ago
Hi everyone,
I imported a .brd file from the Allegro PCB Editor to specctra for autorouting.I set the electrical and physical and spacing rules for the all the nets in the Allegro PCB Editor Constraint Manager but when i exported that to the Specctra Autooruter the spacing rules are not visible.Moreover the nets are routing without these spacing rules(Wire to wire spacing,wire to via spacing etc).But these are following the electrical and physical rules.Can anyone please give a solution to route the nets with the spacing constraints also?Is there any command to autoroute the nets including the spacing rules?
Thanks in advance
Neha.
  • BillZ
    BillZ over 15 years ago
    If you export the brd to Specctra and Launch the router (Specctra) yo have to load the rules.do file. The spacings will then be applied.
    If you launch the router from inside PCb Editor the rules are loaded.
    Route>Route Editor
    BillZ
    EMA Design Automation
  • Neha Anu
    Hi BillZ,
    I usually launch the router from PCB Editor.All the rules except the spacing rules for some nets are not loading.Some of the nets have the spacing rules also for example the wire to wire clearance etc.How can i overcome this situation?
    Thanx
    Neha.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi Neha
    The best thing I can come up with is that you have DRC modes turned off for the constraints that are not getting passed to Specctra.
    Go to Analyze->Analysis modes in Constraint Manager (Setup->Constraints->Modes in PCB Editor)
    Select Spacing Modes and make sure that the constraints are checked in the list. Do the same for same-net-spacing if you have such constraints setup.
    NB: All new constraints introduced in PCB Editor by default have DRC mode set to OFF for backward compability reasons.
    Best regards
    Ole
