  3. Error: Netlister failed in OrCAD PCB designer Basics
  • Views 7571
FormerMember
FormerMember over 15 years ago
Hello to everyone,
I draw a schematic in OrCAD Capture and I also created *.dra footprints. But, when I want to create a netlist and start working in OrCAD PCB Editor I get a strange error. Below is attached Session log. Do anyone have ever similar problem? Do anyone know how to get rid of it?
Thanks.
Marko
* Netlisting the design
Design Name:
e:\projekti\projects\ma_fiberif\lego_if\sch\hfbr_fiber_if.dsn
Netlist Directory:
E:\PROJEKTI\PROJECTS\MA_FIBERIF\LEGO_IF\SCH\ALLEGRO
Configuration File:
C:\Cadence\SPB_16.3\tools\capture\allegro.cfg
Spawning... "C:\Cadence\SPB_16.3\tools\capture\pstswp.exe" -pst -d "e:\projekti\projects\ma_fiberif\lego_if\sch\hfbr_fiber_if.dsn" -n "E:\PROJEKTI\PROJECTS\MA_FIBERIF\LEGO_IF\SCH\ALLEGRO" -c "C:\Cadence\SPB_16.3\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint" -lite -hpath "HPathForCollision"
Unsupported Option HPathForCollision
Exiting... "C:\Cadence\SPB_16.3\tools\capture\pstswp.exe" -pst -d "e:\projekti\projects\ma_fiberif\lego_if\sch\hfbr_fiber_if.dsn" -n "E:\PROJEKTI\PROJECTS\MA_FIBERIF\LEGO_IF\SCH\ALLEGRO" -c "C:\Cadence\SPB_16.3\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint" -lite -hpath "HPathForCollision"
*** Done ***
* Spawning Allegro PCB Editor
Spawing "C:\Cadence\SPB_16.3\tools\pcb\bin\allegro.exe" -orcad -mpssession mlevicnik "e:\projekti\projects\ma_fiberif\lego_if\sch\allegro\hfbr_fiber_if.brd"
*** Done ***
  • oldmouldy
    oldmouldy over 15 years ago
    IMHO, this is properly broken. You need to contact your CCP / Cadence to get this fixed ASAP.
  • Azef
    Azef over 15 years ago
    Please try to do the folowing:
    1. Try to install hotfix7, it seems to be fixed there.
    2. If You cannot use hotfix7 try to generate netlist by command line by running:
    The key is to remove  "HPathForCollision".
    3. Try same command line but different order of parameters:
    "C:\Cadence\SPB_16.3\tools\capture\pstswp.exe" -pst -d "e:\projekti\projects\ma_fiberif\lego_if\sch\hfbr_fiber_if.dsn" -n "E:\PROJEKTI\PROJECTS\MA_FIBERIF\LEGO_IF\SCH\ALLEGRO" -c "C:\Cadence\SPB_16.3\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint" -hpath "HPathForCollision" -lite
    Best Regards,
    Azef.
