  3. How can I view the jrl file as I edit?
  • Subscribers 163
  • Views 18398
Myles
Myles over 16 years ago
I'd like to see the real commands used when I use a pull down, that way I can easily program an alias.
  • Rik Lee
    Rik Lee over 16 years ago
    Enter scriptmode +e in the command window. This echoes the commands you enter in the Allegro command window. Below shows the command 'property edit' from the pulldown Edit >Properties and then you see what was done in the Find Filter.
    Command > scriptmode +e
    CMD> property edit
    Adjust find filter then select an element or group of elements.
    CMD> setwindow form.find
    CMD> FORM find all_off
    CMD> FORM find all_on
    CMD> FORM find name_type Net
    CMD> FORM find find_by_name
    You can also record a script and view that in your favorite text editor to see which commands had been used.
  • Myles
    thanks, I knew there had to be a way
    Myles
  • Myles
    Myles
