  3. Drill legend
  • Views 13523
Drill legend
Goblin59
Goblin59 over 15 years ago
 All,
I have custom drill legends that I have been using for quite a while. They are compact as well as legible. I have run into a problem. I have on my design a mechanical feature that did not allow me to assign a figure,character, width or height. Slot is 190x680 mils. Consequently, when I generate my drill legend, the table is quite elongated and barely fits in the extents. I'm sure the problem is in the oval slot I've created but don't know how to get around this problem. I have done several edits to try to alleviate this behavior. Any help would be great
Cheers,
Ron Scott CID+
  • Randy R
    Randy R over 15 years ago
    One method is to modify your drill chart template; default-mil.dlt (for a design in mils).
    Add the line (where XX is the height you want all figures to be):
    ?FixedFigureHeight     XX
    Note:  This can cause an issue if you're using figure size to differentiate drills.
  • Goblin59
     I've had time to go back and look at this but have still been unsuccessful. I eliminated the slot just to make sure my .dlt was working correctly and it certainly is. The problem is centered around the fact that I can't choose a figure size when creating the slot so in the drill legend the slot is full size and the rest of the legend is spaced as the slot. A most curious problem.
    Ron Scott CID+
  • Goblin59
     Have resolved the problem by following advice on this forum. Adjusted the ?FixedFigureHeight  in the .dlt file and that did the trick. Thanks a bunch!
    Cheers,
    Ron Scott CID+
