  3. How to delete a pin in a package symbol
  • Views 14803
kanonfodder
kanonfodder over 15 years ago
I have a DB9 with 9 pins and 2 mounting holes, but now they want to connect the 2 mounting holes to chassis ground.  I plan on creating a pin 10 and 11 to facilitate this, but am not seeing any way to delete the 2 mounting holes.  I've ran into this before where I might create an extra pin and haven't been able to delete and been forced to recreate the part from scratch.
Mike
  • kanonfodder
     Found it, had to select delete first, then I could change options and select the pin to delete.
