  3. how to increase the row height of drill chart?
  • Subscribers 166
  • Views 18085
girish
girish over 16 years ago
Good day!
How to increase the row height of drill chart? .drill legend title texts ovearlapping due reduced height of row  .(image attached )
how to make the  row height to match automatically to the text height?.
I am using Orcad PCB editor 16.3
REgards,
Girish Kumar
  • steve
    steve over 16 years ago
    Look for default-mil.dlt (under share\pcb\text\nclegend directory). The text and row/column heights are defined in this. If you are using mm then there is default-mm.dlt, in = default-in.dlt and so on.
  • howardcowles
    howardcowles over 16 years ago
    In Allegro 16.2 to get larger rows of drill data the size of the character needs to be larger, or to get the rows tighter a smaller character should be used (if a character for a .500 mil drill is set at .500 mils the row will be over .500)
  • Ragesh
    Ragesh over 16 years ago
                     Try Increasing the Line space of that perticular Text Block
     By default it will  be 9.
    Best Regards,
    RaGZ
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Release 16.3 will give you more flexibility with respect to formatting the drill chart than 16.2 did offer. Look in the template files default-mm.dlt, default-in.etc. dlt for more info.
    Best regards
    Ole
