  3. Concept and generating a list of refdes by page of sche...
  • Replies 10
  • Views 18741
Concept and generating a list of refdes by page of schematic
howardcowles
howardcowles over 15 years ago
Using Concept Schematic HDL
Is there a way to generate a list, by page, of refdes that are on a page?
any help would be appreciated
  • redwire
    redwire over 15 years ago
     Yes.  There is a tool call cross-reference (crefer) which is part of the project manager flow.   It will add concept schematic pages with refdes cross-reference and/or netname cross reference.  Be sure to read the setup manual that goes with it because it can be tricky.
  • howardcowles
    Thanks Redwire
    the engineer used the crefer tool for the off sheet bullets for the signal net names
    that part works fine
    what I was looking for was a way to generate a list of which Ref des were present on each page
    U2, C1, C2, C4, R4, R5 etc on page 2
    U4, C7, D2, SW1 etc on page 3
  • redwire
     And my reply was complete. Crefer does this as well.  Have a look in the manual.
  • tomoo
    tomoo over 15 years ago
    It is true that Crefer can do this, but the output may also include a zone information with a page number depending on the software version.
    Here is another way.
    ## BOM-HDL ##
    1. Run projmgr > Tools > Packager Utilities > Bill of Materials
    2. Template File > Click "Customize"
    3. Report Parameters Tab > RefDes > Select "Unique"
    4. Physical Part Specifications Tab > Check only "BOM_INST" and "PHYS_PAGE"
    5. Save As > Save the BOM template as an appropriate file name > Close
    6. Select "Generate"
    Example of the output
    Ref Des     PHYS_PAGE
    CR2                    2
    CR46                  2
    DAC1                 3
    DAC2                 3
    GA1                    6
    J101                   4
    J102                   4
    Hope this helps.
    Tomo
  • Jerry GenPart
    Jerry GenPart over 15 years ago
    You can run the Cross Referencer (CreferHDL) and generate the report output.
    There’s a report - crefparts.txt – that lists reference designators and the page
    zone details.
    Jerry
