  3. setting the delay and length constraints between T Point...
  • Subscribers 166
  • Views 807
setting the delay and length constraints between T Point(of scheduling) to pins-Allegro_163
MAAC
MAAC over 15 years ago
How to set the length and delay constraints between T point(added during net scheduling) and pins using Allegro PCB Editor(with Performance option)
  • Khurana
    Khurana over 15 years ago
    Create a pin-pair from T-point to the pin then specify the delay values in min/max cells in Min/Max Propagation Delay worksheet within Constraint Manager.
