  3. how to automatically update <RevCode> and <Doc> in Orcad...
  • Replies 9
  • Subscribers 166
  • Views 8569
how to automatically update <RevCode> and <Doc> in Orcad?
speedracer
speedracer over 15 years ago
Can someone show me how to update <RevCode> and <Doc> in the title box in Orcad automatically?
I am trying to avoid doing it sheet by sheet.
Thanx!
-S.R.
  • speedracer
    you are absolutely right.
     Thanx!
     -S.R.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    There's an even easier way instead of having to remember the old dos copy and paste commands.
    In the project manager - right click on the .dsn and select Edit Object Properties
    Now Select the Title Blocks tab and locate the row/columns that you want and select the column/row header and Rightclikc->Edit
    Now type the new RevCode or Doc
    Best regards
    Ole
  • speedracer
    after chating with Cadence people, it is too late for this schematics to insert correct title box automatically.
    I will have to edit each page using method (copy & paste) described by experts here.
    Thanx!
    -S.R.
  • redwire
    redwire over 15 years ago
    Ejlersen said:
    Hi
    I thought you were a fan of keystrokes? :)  Your method works but mine is about 20x faster :)
