  3. Orcad Capture CIS is not save my Variants
  • Subscribers 166
  • Views 14025
JasonJason
JasonJason over 15 years ago
Hi
I open the "part manager" and change variants.
I check in "Variants View Mode" and see the changes.
The problem:
When I Reopen the design somwtimes I do not see the changes (disappear)
My question:
Someone else with same phenomena?
How can I solved that?
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    I'm pretty sure this issue has been fixed in a hotfix - so make sure that you get the latest update to 16.3.
    Best regards
    Ole
  • JasonJason
    we are using 16.2,
  • Ejlersen
    Hi Jason
    Are you using update 003 for 16.2?
    br
    Ole
  • JasonJason
    Hi
    Yes I am using 003, it is not solved this.
    I spoke with the Local support and we decide to upgrade to orcad 16.3 to solved this problem.
  • JasonJason
    Hi
    As you can see below I am using 003.
    This problem is known?
    Upgrade to Orcad 16.3 can help?
