  3. creating pins in symbol editor - Capture 16.3
  • Views 3818
shangwu
shangwu over 15 years ago
 In Capture, how do I put a no connection (NC) pin in a symbol that does not show in the schematic?  I tried Options/Part Properties to turn off the visibility, but that applies to all of the pins.  I only need to turn off the visibilities on certain pins.  Although these NC pins have no electrical connections, I still want them to tie to the footprint.
A second question:
How do I make 2 pins that have the same name.  For example, a chip with 2 or more ground pins.  It complains if I make them the same name (GND).
Thank you.
  • Bennigin
    Bennigin over 15 years ago
    Create a new User Property named "NC" and give it the value of the pin numbers you want to be no connects. For example "1,2,3...".
    For pins to have the same name you have make the  pin Type = Power.
  • shangwu
    Do I create the new user property in symbol editor or in schematic editor?   I did it in the symbol editor and the pins are still there.  How do I hide certain pins?
  • shangwu
    I think I kind of get it although I haven’t tried to generate a netlist.  I delete the NC pins in the symbol editor and add new properties by Options/Part Properties/New….
    Hopefully this will work.
    Thanks.
  • Bennigin
    Yes, you are correct.
