  3. creating board outline artwork
  • Views 13693
stellar
stellar over 15 years ago
 I've done this successfully on prior boards but now drawing a blank and not getting any data in the file according to the fab house. I've tried everything and cannot get any data in my board outline file. Help!
  • Goblin59
    Goblin59 over 15 years ago
     This sounds like a classic problem. In the artwork control for, make sure the "undefined line width" has a value in the box (suggest 8 or 10). This perplexing because you can set your data in your file but when the board house is looking at a gerber there will be nothing in the film unless you define line width.
    Cheers,
    Ron Scott CID+
  • redwire
    redwire over 15 years ago
     And if it is a 0 line width..tsk..tsk...check your logfiles -- they will report this as a warning.
  • stellar
     It appears the only way to create it is with manufacturing/photoplot selected for the artwork. Board outline doesn't seem to work even with minimum line set to something other than 0.
  • Goblin59
     Have you resolved your problem?
