  3. Orcad PCB designer Import logic isn't works
  • Subscribers 163
  • Views 2594
JasonJason
JasonJason over 16 years ago
Hi
when I try imports the netlist I received errors
#1   ERROR(24) File not found
     Packager files not found
#2   ERROR(102) Run stopped because errors were detected
remark-  I do not forget to browse the import wizard to the dat files
  • oldmouldy
    oldmouldy over 16 years ago
    First thing to check is the "netrev.lst" file in the board directory, this will have the import parameters near the beginning of the file to check the paths.
    I guess that you had DE CIS (Capture) checked?
    Spaces in the design / board name or path? Depending on the version, this might cause an issue. Check the name and path for brackets, () [ and <> may cause issues with importing the netlist.
  • JasonJason
    Hi
    • First thing to check is the "netrev.lst" file in the board directory, this will have the import parameters near the beginning of the file to check the paths. - I check that file and do not see any suspicious things, what exactly I am looking for.
    • I guess that you had DE CIS (Capture) checked? YES
    • Spaces in the design / board name or path? Depending on the version, this might cause an issue. Check the name and path for brackets, () [ and <> may cause issues with importing the netlist. - I have short single name under c:\
    what you mean Depending on the version I am using rev 16.2 have any problem wuth that?
