  3. Pad assign color
  • Views 16530
Pad assign color
Adeshere
Adeshere over 15 years ago
I assigned a color to a pad, but now i want them back to the layer color.
How do i do this ?
  • redwire
    redwire over 15 years ago
     Depending on version the name of action changes but the action does not...
    Highlight->Pin to assign a color to a specific pin,pad
    Dehilight->Pin to return to the layer color
    Highlight became "Assign Color" for some mysterious reason in 16.x revs
  • Adeshere
     Ah, does not work.
     In the menu there is
     Assign color  and also highlight color
  • redwire
    Adeshere said:
     Ah, does not work.
    And right below those is "Dehighlight"
  • Adeshere
    I have the following options
     Assign color
     Highlight
     Dehihglight
    Highlight and dehighlight work as expected.
    Its when i use 'Assign color' the pad changes to the new color for ALL layers !!
    I'm guessing there is a tick box somewhere, probably in the color dialog window, but i cant find it
  • Adeshere
     Eventually i found the tick box  ( Why do theymake it so difficult )
    In the Color Dialog under the Nets option, there is a box 'Disable Custom Colors'.
    Placing a tick in this box reverts all to their layer colors instead of assigned colors.
