  3. DXF Question
  • Subscribers 163
  • Views 13980
DXF Question
Dennis H
Dennis H over 16 years ago
 I am working Orcad 16.2 Layout Plus. When I get a DXF from a Mechanical Engineer and load it in it comes in fine, I'll save it to a library file. My question is How do I snap a pad to the center of pad locations on the DXF drawing that I have in the library?
 Under tools there is a snap to Pad,Board, ect. but not to the center of the DXF location (Library part I am makeing).
 Any Help is appreacated.
I hope I didn't confuse you
Thanks, Dennis
  • Goblin59
    Goblin59 over 16 years ago
     Greetings,
     If I understand your question correctly, all you're trying to do is place a pad in the center of the the file. Determine the origin of your part and when you place your pad; simply type in the appropriate coordinates in the command line (e.g. x 1234 y 5678)
    Cheers,
    Ron Scott CID+
  • Dennis H
     Thanks, I'll give it a try.
    Dennis
