  3. two waves for a single IBIS-SI163
  • Subscribers 166
  • Views 12908
MAAC
MAAC over 15 years ago
sometimes after performing si simulation i get two different plots for a single pin as shown below. wht does this signify?
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    When you place an ibisdevice you measure both at the pin and at the die, so this is why there's 2 curves for the same signal.
    Best regards
    Ole
  • MAAC
     which is the one of pin and die..(with i=? wthout i=?)..which one do consider for the analysis..if you have guides on this kindly share!!!!
  • Dennis Nagle
    Dennis Nagle over 15 years ago
    The "i" node is the internal node or the die pin. Which one to use depends on a lot of factors one of which is the accuracy of your package model.
     -Dennis
