  3. IPC Spec for Hard Gold
  • Subscribers 166
  • Views 14597
Goblin59
Goblin59 over 15 years ago
 All,
I'm having a bit of a problem with hard gold process with my board shop. IPC-4552 is the spec for electroless nickel immersion gold so I believe there must be a spec for hard gold. Anyone know what this spec might be?
Cheers,
Ron Scott CID+
  • tomoo
    tomoo over 15 years ago
    FYI
    http://www.circuitexpress.com/pdf/IPC-4552IF ENIG Spec.pdf
    3.2.2  Immersion Gold Thicknes
    Hope this helps.
    Tomo
  • Goblin59
     Tomo,
    I have the ENIG spec but I need one for hard gold. Thanks.
    Cheers,
    Ron Scott CID+
  • Goblin59
     I received an answer from Gary Ferrari(IPC) regarding hard gold standard. It is ASTM-B-488
    Cheers,
    Ron Scott CID+
