  3. How to edit space between shapes in split planes?
  • Views 13940
GINNI
GINNI over 15 years ago
I would like to know how to edit the space between shapes in a split plane. First I put a shape with assigned net name, lets say PWR1 and then I put another shape with assigned net name PWR2 over the fist shape in the same layer. Because it is a split plane the program defines the space between the shapes to 5 mil automatically. So is there a way to change this automatic value to 20 mil for example.
I am working with Cadence SPB 16.2  /  Allegro PCB Design
Thank you for any help on this.
Regards
Gregor
  • oldmouldy
    oldmouldy over 15 years ago
    Go to the Constraint Manager, Setup>Constraints>Spacing, you need to change the Shape to Shape spacing for the net(s), the default value will be 5, hence the spacing that you are seeing.
  • GINNI
    Hi Oldmouldy,
    thank you very much for the competent fast help. That solved the problem.
    Best regards
    Gregor
