  3. How to measure DC resitance of Trace? Pls help me
  • Subscribers 166
  • Views 13230
Lingam
Lingam over 15 years ago
I Need it to measure the DC resitance of partcular length of trace.How to do that in allegero 16.3?
Pls help me. Thanks in advance
Kuthalingam
  • Dennis Nagle
    Dennis Nagle over 15 years ago
    Use the Display > Parasitic command.
  • Lingam
    Thank you.Mr. Dennis Nagle
    Thanks & Regards,
    Kuthalingam
    Sanmina-SCI
  • Khurram
    Khurram over 15 years ago
    I want to share a utility which I have made for calculating trace resistance of all nets on the board. The only limitation of this utility is for internal layer it will use .5OZ of copper and micro strip it uses 1OZ of copper. A doc file with name “Help.doc” is included in it which has instructions for running it.
    Khurram
