  3. How to copy / paste logo from one file to another
  • Views 17198
h2oski
h2oski over 15 years ago
Does Allegro PCB support copy/paste?  I have a completed design which has some shapes used for a company logo.  I'd like to copy that silkscreen information into another board file and don't see any way to accomplish this simple task.
 Thanks for any help,
 Alan
  • oldmouldy
    oldmouldy over 15 years ago
    Chances are that your silkscreen objects are part of a mechanical shape, File>Export>Libraries will get the libraries exported. Add the symbol, probably a BSM to your library path and you should be able to place it as a library part through Place>Manually.
    If they really are "just shapes" in you design, set the colours so that only those objects are visible, then use File>Export>Sub-Drawing, pick the items and an origin and save the "CLP" file. To get this into another design, place the CLP file in the same directory as the design and File>Import>Sub-Drawing, pick the sub-drawing from the list.
    Making a library part from the sub-drawing might make it easier to make the logo available to other designs.
  • h2oski
    Thanks.. that worked!
