  3. updated OrCAD from 16.3S005 to 16.3S009
  • Subscribers 166
  • Views 12649
shangwu
shangwu over 15 years ago
 I recently updated OrCAD from 16.3S005 to 16.3S009 and things behavior strangely.
1.    It hangs up more often.
2.    The “Add Connect/Snap to connect point doesn’t work.”  Therefore, I have to set the grid to 1 mil in order to connect exactly where the rats nets are.  This is very annoying.
3.    It allows 2 different nets to connect/cross (the push/hug do not work).  I think it may be related to problem #2 since the new trace is not considered connected to the net.
All these may be simply a setting problem, but I couldn’t find it.
Any clue on this issue?  Thanks.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    I cannot remember this from s009, you could always try updating to s011 which is the newest update-
    Are you sure that pins are enabled in your find filter - this is the most typical problem when snap to connect point don't work.
    Best regards
    Ole
  • shangwu
     Ole,
    You've always been very helpful.  That's right.  The pins were not enabled (by default) after upgrading to the new version.  Thanks for your help.
