  3. board outline_line with different angle
  • Subscribers 166
  • Views 12973
MAAC
MAAC over 15 years ago
 How can i set the angle (except 45,90) for Board Geometry Outline_line in Allegro PCB Editor. Apart from 45 & 90, i am unable to set any odd angle to draw the line for the outline.
  • jhorner
    jhorner over 15 years ago
    You can't set it to a specific angle, but you can set it to "off" which allows for any angle.
    As a guide, you can set the pcb_cursor_angle in the user preferences
  • Goblin59
    Goblin59 over 15 years ago
     Maac,
    If you have access to AutoCad or Solidworks, you can generate your board outline in a .dxf and then import. IMO, the easiest and most efficient method. Maybe you can snag an ME to do it for you :)
    Cheers,
    Ron Scott CID+
  • Cadpro2K
    Cadpro2K over 15 years ago
    Ditto Ron. So much easier to import odd angle, complicated outlines. And it's easy.
