  3. How to generate layerstackup details
  • Views 12595
Raam
Raam over 15 years ago
Is it possible to generate the layer stack up details for manufacturer? ( like drill chart )..
  • Rik Lee
    Rik Lee over 15 years ago
    Cadence Online Support solution 11622338 refers to a SKILL prgram with some documentation that will allow you to create a detail drawing much like a drill chart that I believe will provide what you need.
    ~Rik
  • Cadpro2K
    Cadpro2K over 15 years ago
    For drill chart, that's created when you run Manufacturing/NC/Drill Chart - you'll need to turn on the layers it generates (you'll find them under the Manufacturing subclass
    The stackup can be created with with this little example attached. It's pretty universal.
    6-Lyr_Stackup.zip
