  3. OrCAD Capture hangs there forever when generating the PCB...
  • Subscribers 167
  • Views 16144
OrCAD Capture hangs there forever when generating the PCB Editor netlist!
Peyton
Peyton over 15 years ago
I have created a middle size schematic. The DRC check has no errors. But Capture hangs there forever in the "netlisting the design" step with no error session logs. I have spent two days checking the reference designators and footprints. It works for generating other format's netlist. Just not for PCB Editor netlist.
Still cannot find the reason. Hope somebody has run into similar problems and solved it. Really need help!
  • steve
    steve over 15 years ago
    Take a look at /forums/T/16060.aspx If you are running Capture on Windows 7 or Vista.
  • Peyton
    The problem is partially solved. I replaced all the inductors, capacitors, and resistors in the cache by recreated library parts. Because I found some of their pin numbers were missing. But I still got many warnings. Most of them are about renaming the parts. I don't know why the parts' names are so long and where to review and edit them.
    Spawning... "C:\Cadence\SPB_16.2\tools\capture\pstswp.exe" -pst -d "C:\Project\mRouter\mrouter bcsm352 0703.dsn" -n "C:\Project\mRouter\allegro" -c "C:\Cadence\SPB_16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
    #1 Warning [ALG0016] Part Name "C0402_C0603_4.7UF_5044-001-000292" is renamed to "C0402_C0603_4.7UF_5044-001-0002".
    #2 Warning [ALG0016] Part Name "C0402_C0402_15PF_5044-001-000292" is renamed to "C0402_C0402_15PF_5044-001-00029".
    #3 Warning [ALG0016] Part Name "CAP, 0.47UF, EMI FILTER_CFLTR_0.47UF" is renamed to "CAP, 0.47UF, EMI FILTER_CFLTR_0".
    #4 Warning [ALG0016] Part Name "LED, GREEN, SMT, 0603_LED0603_GREEN" is renamed to "LED, GREEN, SMT, 0603_LED0603_G".
    #5 Warning [ALG0016] Part Name "ANTENNA_MURATA_LDA316G2013F-250_LDA316G2013F-250" is renamed to "ANTENNA_MURATA_LDA316G2013F-250".
    #6 Warning [ALG0016] Part Name "HIROSE_DM1AA-SF-PEJ_DM1AA-SF-PEJ21_HIROSE_DM1AA-SF-PEJ" is renamed to "HIROSE_DM1AA-SF-PEJ_DM1AA-SF-PE".
    #7 Warning [ALG0016] Part Name "MOLEX_56579-0576_56579-0576_MOLEX_56579-0576" is renamed to "MOLEX_56579-0576_56579-0576_MOL".
    #8 Warning [ALG0016] Part Name "IND, CM CHOKE, SINGLE, DLW21S_DLW21SN900SQ2_DLW21SN900HQ2" is renamed to "IND, CM CHOKE, SINGLE, DLW21S_D".
    #9 Warning [A
    LG0016] Part Name "IND, BEAD, BLM15EG121_I0402_BLM15EG" is renamed to "IND, BEAD, BLM15EG121_I0402_BLM".
    #10 Warning [ALG0016] Part Name "IND, BEAD, BLM15PD800SN1_I0402_3.3UH" is renamed to "IND, BEAD, BLM15PD800SN1_I0402_".
    #11 Warning [ALG0016] Part Name "R0402_R0402_1.2K_5044-001-000106" is renamed to "R0402_R0402_1.2K_5044-001-00010".
    #12 Warning [ALG0016] Part Name "R0402_R0402_1.8K_5044-001-000106" is renamed to "R0402_R0402_1.8K_5044-001-00010".
    #13 Warning [ALG0016] Part Name "THERMISTOR_2_0603_B57371V2103J060" is renamed to "THERMISTOR_2_0603_B57371V2103J0".
    #14 Warning [ALG0016] Part Name "IC, SPDT, 6GHZ, UPG2176T5N_UPG2176T5N_SPDT" is renamed to "IC, SPDT, 6GHZ, UPG2176T5N_UPG2".
    #15 Warning [ALG0016] Part Name "RES, 4.7K, THERMISTOR, 0603_R0603_4.7K NTC" is renamed to "RES, 4.7K, THERMISTOR, 0603_R06".
    #16 Warning [ALG0016] Part Name "TEST POINT, SMT_SMT_TP_20M_TEST POINT, PIN" is renamed to "TEST POINT, SMT_SMT_TP_20M_TEST".
    #17 Warning [ALG0016] Part Name "TEST POINT, SMT_TESTPOINT_THROU
    GH_TEST POINT, PIN" is renamed to "TEST POINT, SMT_TESTPOINT_THROU".
    #18 Warning [ALG0016] Part Name "IC, ASIC, BCSM352-2, 13X13MM_0_BCSM352_BCSM352-2_13X13" is renamed to "IC, ASIC, BCSM352-2, 13X13MM_0_".
    #19 Warning [ALG0016] Part Name "SYCHIP 802_7.11N _8787MODULE_SYCHIP 802_7.11N" is renamed to "SYCHIP 802_7.11N _8787MODULE_SY".
    #20 Warning [ALG0016] Part Name "FCX-05-40M-001_6_SG-30XXJC_SG-3030JC" is renamed to "FCX-05-40M-001_6_SG-30XXJC_SG-3".
    #21 Warning [ALG0016] Part Name "RIVER_FCX-07_FCX-06_FCX-06-38.4M" is renamed to "RIVER_FCX-07_FCX-06_FCX-06-38.4".
    #22 Warning [ALG0016] Part Name "FCX-05-40M-001_4_FCXO-05_FCXO-05-38.4M" is renamed to "FCX-05-40M-001_4_FCXO-05_FCXO-0".
    #23 Warning [ALG0016] Part Name "TI_TPD6E001RSER_TI_TPD6E001RSER_TI_TPD6E001RSER" is renamed to "TI_TPD6E001RSER_TI_TPD6E001RSER".
    #24 Warning [ALG0016] Part Name "LDB182G5005G_LFL182G54TC1B838_LDB182G5005G" is renamed to "LDB182G5005G_LFL182G54TC1B838_L".
    #25 Warning [ALG0051] Pin "GND" is renamed to "GND#2" after subst
    ituting illegal characters in Package LDB182G5005G , U15: SCHEMATIC1, .05.RF I/F (5.85, 2.55).
    #26 Warning [ALG0051] Pin "GND" is renamed to "GND#5" after substituting illegal characters in Package LDB182G5005G , U15: SCHEMATIC1, .05.RF I/F (5.85, 2.55).
    #27 Warning [ALG0016] Part Name "IC, RF AMP, 3 GHZ, MGA-645T6_MGA_645T6_MGA-645T6" is renamed to "IC, RF AMP, 3 GHZ, MGA-645T6_MG".
    #28 Warning [ALG0016] Part Name "FILTER, BPF, 2.3-2_0.7GHZ, LTCC_LFB18_LFB182G60SGHB972TEMP" is renamed to "FILTER, BPF, 2.3-2_0.7GHZ, LTCC".
    #29 Warning [ALG0051] Pin "GND" is renamed to "GND#1" after substituting illegal characters in Package FILTER, BPF, 2.3-2_0.7GHz, LTCC , U17: SCHEMATIC1, .05.RF I/F (12.35, 2.45).
    #30 Warning [ALG0051] Pin "GND" is renamed to "GND#3" after substituting illegal characters in Package FILTER, BPF, 2.3-2_0.7GHz, LTCC , U17: SCHEMATIC1, .05.RF I/F (12.35, 2.45).
    #31 Warning [ALG0016] Part Name "IC, MAX809SQ, 2.93V, SOT323_SOT-323_MAX809SQ293T1G" is renamed to "IC, MAX809SQ, 2.93V, SOT323_S
    OT".
    #32 Warning [ALG0016] Par
    t Name "IC, PA, 2.3-2_0.7GHZ, AWT6264_AWT6264R_AWT6264" is renamed to "IC, PA, 2.3-2_0.7GHZ, AWT6264_A".
    #33 Warning [ALG0016] Part Name "FILTER, LPF, 2_1.7GHZ, LTCC_LFL182G54TC1B838_LFL182G54TC1B838TEMP" is renamed to "FILTER, LPF, 2_1.7GHZ, LTCC_LFL".
    #34 Warning [ALG0051] Pin "GND" is renamed to "GND#2" after substituting illegal characters in Package FILTER, LPF, 2_1.7GHz, LTCC , U21: SCHEMATIC1, .05.RF I/F (11.35, 4.65).
    #35 Warning [ALG0051] Pin "GND" is renamed to "GND#5" after substituting illegal characters in Package FILTER, LPF, 2_1.7GHz, LTCC , U21: SCHEMATIC1, .05.RF I/F (11.35, 4.65).
    #36 Warning [ALG0016] Part Name "IC, BATTERY MONITOR, STC3100_1_STC3100_STC3100" is renamed to "IC, BATTERY MONITOR, STC3100_1_".
    #37 Warning [ALG0016] Part Name "IC, TVS ARRAY, 6V, SC-88_ON_SC-88_TVS ARRAY" is renamed to "IC, TVS ARRAY, 6V, SC-88_ON_SC-".
    #38 Warning [ALG0016] Part Name "S25FL128P_S25FL128P_S25FL128P0XMF" is renamed to "S25FL128P_S25FL128P_S25FL128P0X".
    #39 Warning [ALG0016] Part Name "IC,
    DDR RAM, 512MB, MT46H32M16_BGA60_12X10_MT46H32M16LF" is renamed to "IC, DDR RAM, 512MB, MT46H32M16_".
    #40 Warning [ALG0051] Pin "VSSQ" is renamed to "VSSQ#A3" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #41 Warning [ALG0051] Pin "VDD" is renamed to "VDD#K9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #42 Warning [ALG0051] Pin "VDDQ" is renamed to "VDDQ#A7" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #43 Warning [ALG0051] Pin "VSS" is renamed to "VSS#A1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #44 Warning [ALG0051] Pin "VDD" is renamed to "VDD#A9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INT
    #45 Warning [ALG0051] Pin "VDD" is renamed to "VDD#F9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #46 Warning [ALG0051] Pin "VDDQ" is renamed to "VDDQ#D1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #47 Warning [ALG0051] Pin "VDDQ" is renamed to "VDDQ#B1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #48 Warning [ALG0051] Pin "VSSQ" is renamed to "VSSQ#C1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #49 Warning [ALG0051] Pin "VSSQ" is renamed to "VSSQ#B9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #50 Warning [ALG0051] Pin "VSSQ" is renamed to "VSSQ#
    D9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #51 Warning [ALG0051] Pin "VDDQ" is renamed to "VDDQ#C9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #52 Warning [ALG0051] Pin "VSS" is renamed to "VSS#F1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #53 Warning [ALG0051] Pin "VSS" is renamed to "VSS#K1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #54 Warning [ALG0051] Pin "VDDQ" is renamed to "VDDQ#E9" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H32M16 , U7: SCHEMATIC1, .03.MDDR INTERFACE (10.00, 2.00).
    #55 Warning [ALG0051] Pin "VSSQ" is renamed to "VSSQ#E1" after substituting illegal characters in Package IC, DDR RAM, 512Mb, MT46H
    #56 Warning [ALG0016] Part Name "DUAL BAND WLAN/BT ANTENNA_5_2450AD46A5400_2450AD46A5400" is renamed to "DUAL BAND WLAN/BT ANTENNA_5_245".
    #57 Warning [ALG0016] Part Name "MM8430-2600RA1_1_MURATA_MM8430-2610_MM8430-2610" is renamed to "MM8430-2600RA1_1_MURATA_MM8430-".
    #58 Warning [ALG0016] Part Name "CONN, COAX SW_MURATA_MM8130-2600_MM8130-2600RA1" is renamed to "CONN, COAX SW_MURATA_MM8130-260".
    #59 Warning [ALG0016] Part Name "CRYSTAL, 32.768KHZ, 3.2X1.5MM_RIVER_TFX-03_TFX-03 32.768KHZ" is renamed to "CRYSTAL, 32.768KHZ, 3.2X1.5MM_R".
    #60 Warning [ALG0016] Part Name "CRYSTAL, 40MHZ, 2_1.5X2MM_CX2520SB_40MHZ CRYSTAL" is renamed to "CRYSTAL, 40MHZ, 2_1.5X2MM_CX252".
    #61 Warning [ALG0051] Pin "GND" is renamed to "GND#4" after substituting illegal characters in Package CRYSTAL, 40MHz, 2_1.5X2MM , Y2: SCHEMATIC1, .05.RF I/F (0.75, 6.05).
    #62 Warning [ALG0051] Pin "GND" is renamed to "GND#2" after substituting illegal characters in Package CRYSTAL, 40MHz, 2_1.5X2MM , Y2:
    Scanning netlist files ...
    Loading... C:\Project\mRouter\allegro/pstchip.dat
    Loading... C:\Project\mRouter\allegro/pstxprt.dat
    Loading... C:\Project\mRouter\allegro/pstxnet.dat
    packaging the design view...
    Exiting... "C:\Cadence\SPB_16.2\tools\capture\pstswp.exe" -pst -d "C:\Project\mRouter\mrouter bcsm352 0703.dsn" -n "C:\Project\mRouter\allegro" -c "C:\Cadence\SPB_16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
    *** Done ***
  • Peyton
    The problem is not because of the user permission of Vista. The problem is solved by replacing all the Ls, Cs, and Rs in the design by new created components. All the Ls are with one L0402 footprint, the Cs with C0402, and the Rs with R0402.
  • eephillip
    eephillip over 15 years ago
    That looks like a good netlist to me, you can't do anything about the renaming. It is combining multiple part fields into a long string and then truncating it. I was told not to worry about it. One thing did bother me though, do you have spaces in your file name or path? That will cause some pain.
  • swang
    swang over 15 years ago
    I also met this issue, and if I change the DSN file name and path, the issue maight be fixed sometimes. it hangs at "packaging the design view ... ".
