  3. possible to change curser color???
  • Subscribers 163
  • Views 15980
kabalee
kabalee over 16 years ago
Hi
anybody please tell how to change the curser color in PCB editor (allegro)
  • uamcap27
    uamcap27 over 16 years ago
     Kabalee,
    I dont think for a possible way to change the color of the cursor. However you can adjust the cursor's color by changing your background color under color visibility>display. Cursor's color automatically changes depending on your backgrounds color.
  • kabalee
     uamcap27,
    thank you for your information.i  am learning 4 layer and 6 layer  design.did you know  what are procedure to follow the 4 layer design and 6 layer ..
  • uamcap27
    Kabalee,
    What do you exactly mean? If you mean setting the layers, you can go to setup>cross section.
  • kabalee
     uamcap27
    no i am asking when opening the cross section physical thickness,film type have given what is the use of it .
