  3. customized drill chart question
  • Subscribers 163
  • Views 13972
SevenFortyOne
SevenFortyOne over 15 years ago
Greetings,
 I'm working on setting up a customized drill chart.  I've created a new ".dlt" file by copying the default and have made some changes successfully.
One of the changes I've made is to add a blank "user" collumn.  I've also set up a a few rules under the "?CustomData" section to populate the collumn with data when appropriate and is left blank if nothing matches the "?CustomData" list.
Is there a way to specify a defualt value for the "user" collumn instead of leaving it blank if there is no match to the "?CustomData" list?
 Thanks!
  • oldmouldy
    oldmouldy over 15 years ago
    No, the value in the "drill size" column has to match a numerical pattern "xx.xx", attempting to get a "wildcard" match will get an error message.
  • oldmouldy
