  3. unused Vias deleting
  • Views 18813
stellar
stellar over 15 years ago
I've done some reroutes and had to cut out some regions of tracks and vias but have some unused vias sprinkled around the board. Gloss doesn't appear to clean it up.
  • fxffxf
    fxffxf over 15 years ago
     As long as you are running 16.2 or newer the Dangling Line Report will show these vias in the Dangling Via section of the report no matter what license of Allegro is being used.
    You need to be careful when adding vias when shapes are present because if you drop an isolated via it may connect to a shape and more if more then one connection is generated it is no longer considered to be dangling.
  • fxffxf
