  3. artwork problem
  • Views 12850
artwork problem
purikku22
purikku22 over 15 years ago
hi, had a slight problem denerating my artwork using rs274x, this aperture always shows in the list of aperture being used, how can i remove this one? CIRCLE 0.00000 DARK my settings are as follows: FILM PARAMETERS : --------------------------------------------------------- Undefined line width 0.0000 Mirror code NONE Rotate angle NONE Offset x: 0.0000 Offset y: 0.0000 Plot negative NO Suppress unconnected internal pads NO any help would be appreciated. thanks in advance,.
  • uamcap27
    uamcap27 over 15 years ago
    Sir eric,its me mau.try check your artpath or aptpath if aperture circle 0.0000 exist.Im also using rs274x device, my setting are as follows;try using this one, i have no problem encountered.
    under film control
    -rotation----0 offset---0,0 undefined linewidth---with value(min. linewidth we used esp. on txt) shape bounding box---0 plot mode---positive
    with check mark---vector based pad behavior.
    under general params
    error action;abort film  format;5.5  suppress; leading and equal with check mark.
    try also check your films... i dont exactly know the cause..but maybe we can figure it out
  • purikku22
    mau, already figured it out, the circle 0.0000 was used for the NTH,
    since i declared their land size as 0,
    according to the fab house it is not a problem, only sir oone was the
    one causing a fuss! :D.
    thanks for your reply!
    > under film control
    > check mark.
    > You received this email because you subscribed to notifications for
    > the Cadence PCB Design Forum. To unsubscribe, log in, go to forums,
    > and change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
