  3. view of bottom
  • Subscribers 163
  • Views 17367
view of bottom
kabalee
kabalee over 16 years ago
hi all,
how to view bottom symbol or hole bottom symbol without generating gerber???
  • girish
    girish over 16 years ago
    Ur Question is not so clear !
    If u are using allegro16.3ver use Flip design option to view the true bottom view
    OR
    print pdf with mirror image
    Girish Kumar
  • kabalee
     hi
    i placed the symbol bottom side.i like to see the symbol only in bottom side for my routing perpose it is possible.??
  • girish
    • Make global visibility off in color dialogue & apply
    • enable one by one what and all u want in board file to view for e.g.:
      1.
        • Board Geometry /BOTTOM
        • Board Geometry / Outline
        • Via Class /BOTTOM
        • Pin/BOTTOM
        • Etch /BOTTOM
        • ....et.c
    • apply OK.
    • go to ,MANUFACTURE-artwork-film control add new film class ("BOTTOM") ,right click on that & give match display .
    • give OK
    • Then in the visibility u can view these setting .
    Like this u can define ur visibility settings .
    Hope this may help
    Girish Kumar
