  3. Why no font when i DXF in.
  • Subscribers 163
  • Views 17923
Jimdive
Jimdive over 15 years ago
i have lots of words in dxf of AUTOCAD file . when i import DXF file to my project. there is no font in it, but figure is all right. Allegro says as follow. How i can deal with it.  Many thanks for any reply.
Reading Layer Conversion File
Reading DXF file...
NOTE: Replacing illegal character * with X in *Model_Space.
NOTE: Replacing illegal character * with X in *Paper_Space.
NOTE: Replacing illegal character * with X in *Paper_Space0.
NOTE: Replacing illegal character * with X in *D3.
NOTE: Replacing illegal character $ with X in A$C07CC1D63.
NOTE: Replacing illegal character * with X in *D5.
NOTE: Replacing illegal character * with X in *D6.
NOTE: Replacing illegal character * with X in *D7.
NOTE: Replacing illegal character * with X in *D8.
NOTE: Ignoring unsupported element SPLINE on line 101468.
NOTE: Ignoring unsupported element SPLINE on line 101640.
NOTE: Ignoring unsupported element SPLINE on line 101812.
NOTE: Ignoring unsupported element SPLINE on line 102012.
NOTE: Ignoring unsupported element SPLINE on line 107110.
NOTE: Ignoring unsupported element SPLINE on line 107450.
NOTE: Ignoring unsupported element HATCH on line 46932.
NOTE: Ignoring unsupported element SPLINE on line 107930.
NOTE: Ignoring unsupported element SPLINE on line 108214.
NOTE: Ignoring unsupported element HATCH on line 49834.
NOTE: Ignoring unsupported element SPLINE on line 108806.
NOTE: Ignoring unsupported element SPLINE on line 109048.
NOTE: Ignoring unsupported element SPLINE on line 109248.
NOTE: Ignoring unsupported element SPLINE on line 109448.
NOTE: Ignoring unsupported element HATCH on line 54372.
NOTE: Ignoring unsupported element SPLINE on line 109718.
NOTE: Ignoring unsupported element SPLINE on line 109890.
WARNING: Ignoring zero length segment at (5904.0311, -1494.0946)
NOTE: Ignoring unsupported element MTEXT on line 111210.
NOTE: Ignoring unsupported element MTEXT on line 111292.
NOTE: Ignoring unsupported element MTEXT on line 111374.
NOTE: Ignoring unsupported element MTEXT on line 111456.
NOTE: Ignoring unsupported element MTEXT on line 111538.
NOTE: Ignoring unsupported element MTEXT on line 111620.
NOTE: Ignoring unsupported element MTEXT on line 111702.
NOTE: Ignoring unsupported element MTEXT on line 111784.
NOTE: Ignoring unsupported element MTEXT on line 113394.
NOTE: Ignoring unsupported element MTEXT on line 113470.
NOTE: Ignoring unsupported element MTEXT on line 113546.
NOTE: Ignoring unsupported element MTEXT on line 113622.
NOTE: Ignoring unsupported element MTEXT on line 113698.
NOTE: Ignoring unsupported element MTEXT on line 113774.
NOTE: Ignoring unsupported element MTEXT on line 113850.
NOTE: Ignoring unsupported element MTEXT on line 113926.
NOTE: Ignoring unsupported element MTEXT on line 114002.
NOTE: Ignoring unsupported element MTEXT on line 114078.
NOTE: Ignoring unsupported element MTEXT on line 114154.
Layer conversion file: D:/Project/project_three/2MID2/figure/pcb_3g_wifi3_l.cnv
DXF file: D:/Project/project_three/2MID2/figure/pcb_3g_wifi3.dxf
BRD file: #Taaaaaa03608.tmp
Update existing design?: YES
Use default text?: YES
DXF units: MILLIMETERS
Design units: MILS
Design precision: 2
  • mcatramb91
    mcatramb91 over 15 years ago
    Not sure if it will help or not but I always output the DXF file in the lowest DXF version (V12.0) as to possibly avoid any compatibility issues.  Also I EXPLODE all elements to their lower levels to ease the translation into Allegro.  I have a stepped process by first saving the DXF to the lower version and if I don't get the results I am looking for I start to EXPLODE elements.
    Hope this helps,
    Mike Catrambone
  • Jimdive
    yes, you are right. Mike Catrambone. you solved my problem. when i converte DXF to AutoCAD R12 version, it is OK now. Thank your again.
