  3. Want to make shortcut
  • Subscribers 163
  • Views 14570
Tanveer
Tanveer over 15 years ago
Hi All,
I want to assign a key to toggle between arc and line in the option "Line Lock" during Routing.can I do it by editing env file and what should be the command to set this shortcut.
Best Regards
Tanveer
  • redwire
    redwire over 15 years ago
     Hi Tanveer -- glad it worked.  What I meant by your "Allegro directory" was where the .brd file that you were editing was.  Glad you solved the alternative path -- that way it will work with all future projects as well.
    Redwire.
  • redwire
    Redwire.
