  3. "synonym like" function (net alias) for CIS?
  • Views 4295
Cadpro2K
Cadpro2K over 15 years ago
Has anyone done 'net aliasing' inside CIS, or can it be done? In HDL you an have 2 signals on each side of a synonym symbol, and you get one net (it combines them into 1 net name). Can this be done in CIS somehow?
Tx
  • Khurana
    Khurana over 15 years ago
    Why do you think you need this?  Please identify the reason and explain the situation you're in.
  • Cadpro2K
     The engineer would like to have the schematic 'read' easier for development. He's like to have the signal have one "common" name, but have 2-3 other names where they terminate (e.g. start out as CONTROL; then at one end (termination) be CONTROL_BT; and another end be CONTROL_FM). In HDL I can use the synonym symbol to combine names together. Don't see it in CIS.
  • redwire
    redwire over 15 years ago
     Don't need the net alias symbol in OrCAD CIS -- it's native.  Just name the wire with both names and CIS takes care of reducing it into one name. You can see the result during DRC warnings...
