  3. Capture 16.3 - Can't move any component in schematic
  • Subscribers 166
  • Views 6289
shangwu
shangwu over 15 years ago
I created a schematic in Capture 16.3 and I can no longer move any part or net.  Whenever I try to move anything, it shows "Object move not completed as this resulted in connectivity changes".  Does anyone know how to solve this?
Thanks.
I'm using 16.3-S014
  • shangwu
    I guess I found the problem.
    There are some connections that OrCAD just didn't like.  As long as I delete these connections, it allows me moving parts, even though these problematic points have nothing to do with some other components.
  • hw123
    hw123 over 12 years ago
     Did anyone found the actual solution to the problem
  • hw123
     I also had the same problem and finally found the solution. It was not by deleting other componet.
    Check out this solution here
  • TH Designs
    TH Designs over 12 years ago
    Options - Preferences - Misc
    Make sure "Allow component move with connectivity changes" is selected.
  • NK47
    NK47 over 11 years ago
    Creating a new page and copy, pasting components to it worked for me
