  3. Assembly as searchable pdf
  • Replies 7
  • Subscribers 166
  • Views 18514
Kija
Kija over 15 years ago
 Hej
Is there any way of making a pdf file for assembly that is searchable? Meaning that i want to create an assembly for top and bottom as a pdf and then be able to search for a given component in that pdf.
Regards
 Kim
  • Carvey
    Carvey over 14 years ago
    Searchable text has to be defined in PLOT SETUP.
    Under the WINDOWS TAB
    Select Non-vectorized text check box
    Then you must select the font character, we use Courier
    We typically don’t have components on the back side of our designs.
    Are you using a third party software program to create your assembly drawings?
    We use the same software program, PCB EDITOR to create our assembly drawings.
    Carvey Ready
    PCB Designer III
    Lester Electrical of Nebraska, Inc.
    (402) 477-8988 Ext. 114
    carveyr@lesterelectrical.com
  • Carvey
    Carvey Ready
    PCB Designer III
