  3. same pin name for multiple pins.
  • Subscribers 166
  • Views 17710
anandaraj
anandaraj over 15 years ago
hi,
can anybody tell me, is there any option in capture to give same name for morethen one pin.
thanks in advance.
 Anand.
  • Anaxroche
    Anaxroche over 15 years ago
    hi anandaraj, you can have the same pin name by changing the pin type.right click on the component and edit part.double click the pin that you want to change type and from pin properties menu change type as "power".You should change pin type for all pins that will have the same name.
  • anandaraj
    thanks for your immediate reply.
    anand
